24.04.2009, 21:45 | #1 |
фотогалерея работает?
Что-то у меня вторую неделю не работает фотогалерея, на пустой страничке Fatal error : Может я чего пропустил?
24.04.2009, 22:40 | #2 |
И у меня.
наверное хакеры |
25.04.2009, 00:51 | #3 |
+1.
25.04.2009, 21:02 | #4 |
Ауу... админы, подскажите в чём дело плз...
26.04.2009, 16:03 | #5 | |
27.04.2009, 17:42 | #6 |
Ура, заработало, спасибо!
25.05.2009, 11:18 | #7 |
а чего случилось с кодировкой? вместо названия альбомов- ряды вопросительных знаков
04.06.2009, 18:15 | #8 |
И что, у всех все работает?
У меня уже который день вместо галереи тестовая страница тетушки Федоры из племени Апачей: Fedora Core Test Page This page is used to test the proper operation of the Apache HTTP server after it has been installed. If you can read this page, it means that the web server installed at this site is working properly, but has not yet been configured. -------------------------------------------------------------------------------- If you are a member of the general public: The fact that you are seeing this page indicates that the website you just visited is either experiencing problems, or is undergoing routine maintenance. If you would like to let the administrators of this website know that you've seen this page instead of the page you expected, you should send them e-mail. In general, mail sent to the name "webmaster" and directed to the website's domain should reach the appropriate person. For example, if you experienced problems while visiting www.example.com, you should send e-mail to "webmaster@example.com". For information on Fedora Core, please visit the Fedora Project website. -------------------------------------------------------------------------------- If you are the website administrator: You may now add content to the directory /var/www/html/. Note that until you do so, people visiting your website will see this page, and not your content. To prevent this page from ever being used, follow the instructions in the file /etc/httpd/conf.d/welcome.conf. You are free to use the images below on Apache and Fedora Core powered HTTP servers. Thanks for using Apache and Fedora Core! |
04.06.2009, 18:49 | #9 |
У меня тоже самое, уже недели две как не работает, а буквально позавчера и форум не работал, часть тем открывались, а часть тем выдавали ошибку при попытки открыть.
11.06.2009, 17:56 | #10 |
Ну дык в конце концов что с галлереей, может кто объяснит? Или это у меня глюк???
ФОТОГАЛЕРЕЯ | Lobkor | Беларусь | 181 | 23.08.2019 12:32 |
Ну не работает и все! | кап.5 | Электрооборудование (Electrical Equipment) | 9 | 25.10.2009 16:20 |
Фотогалерея не работает. | Lom35 | Прочее | 1 | 09.08.2009 09:22 |
не работает | chill | Прочее | 0 | 12.05.2009 21:19 |
как оно работает | Peresmeshnik | Трансмиссия и Ходовая часть (Transmission) | 2 | 18.12.2007 11:18 |
