10.04.2007, 11:28 | #1 |
Problems with Gearbox Sounds Patriot / Hunter Dymos
Dear Collegues,
as result of research with LUK Company its now possible to have no gearbox sounds on 3163 and 315195 with DYMOS when you will use the LUK Set 3 024 G40 00. This sets eliminates all sounds when you drive with low rpms; they completely disapear and its much more comfort and less use of petrol. (try to drive 50 km / h with 5th gear!!!!) |
22.04.2007, 11:35 | #2 |
It's nice to hear, but
- Where I can get this set? - Can you make some brief description of this set implementation? Thanks in advance |
22.04.2007, 17:41 | #3 |
Yes it is very interesting, but it in Germany to it is easier get this set.
Long looked at this post when anybody will answer |
22.04.2007, 22:16 | #4 |
Could you please post more information for this set?
I can't find item numbered 3 024 G40 00 in LuK online catalog. The closest found number is 3 024 840 00. |
24.04.2007, 14:22 | #5 |
Сайт данного человека, занимаются поставками в германию уазов... там и контактики есть http://www.baijah.de/
имно сцепление здесь не причем... хоть целиком другое ставь звук от раздатки будет всеравно... ниже 2х тысяч оборотов... |
24.04.2007, 15:39 | #6 | |
24.04.2007, 16:15 | #7 |
Бедные немцы, вот им уаз сдался))) теперь мучаются)) вот тут уже плачет о перегреве... http://forum.uazbuka.ru/showthread.php?t=21062
29.05.2007, 10:46 | #8 |
And the price tell please
31.05.2007, 20:39 | #9 |
Agree that clutch (сцепление) is reason for this sound. As experiment I changed cluitch's disk from LuK to Russian-made Trek. Sound changed significantly - unfortunately not to reduction of it but to more loud and appear with other rpm (mostly when I try to decrease speed by engine instead of take-off run before.
Hope that this issue have solution! But! LuK clutch's disk looks very unreliable due to very light metal construction, so I want to get something more reliable. Trek's disk is working well and already tested in hard off-road. |
02.08.2007, 14:19 | #10 |
Назвали уточненный номер:
L-03024-0g40-00 L-03024-0g40-00 A00 Последний раз редактировалось sinmaks; 02.08.2007 в 15:54. |
Замена сцепления Hunter ЗМЗ409 Dymos | RomaST | Трансмиссия и Ходовая часть (Transmission) | 4 | 18.02.2009 16:23 |
Patriot, Hunter Евро3 | Legion | Обсудим автомобили | 1 | 20.02.2008 18:01 |
Hunter Gearbox problems | UAZ UK | Трансмиссия и Ходовая часть (Transmission) | 12 | 20.10.2006 16:43 |
Hunter gearbox problems | UAZ UK | UAZ International | 1 | 17.10.2006 16:53 |
UAZ Hunter 513195-035 (с КПП Dymos и ЗМЗ-409) | Lobo | Обсудим автомобили | 11 | 31.10.2005 00:46 |
