03.03.2006, 09:57 | #31 |
Maurice,
I think in that case it would be easier to start from an old vehicle. Doing alterations to a car is much easier then fighting bureaucracy. After all, even repacing everything in a car is reasonably inexpensive. Parts prices are: Body ~$2000 Ebgine: ~$1500 Gearbox: ~$400 Driveshafts: ~$150 (2 of them) Axles: $1500 (Army type with wheel rediction units) Civil ones are cheaper. Chassis: $800 Power steering kit: $400-$800 (depending on the componets' manufacturers) Engine can almost always be rebuilt to specs of a new engine because old type UAZ engine has removeable cylinders. Yorus, Dmitri |
03.03.2006, 18:41 | #32 | |
It should also be cheaper. The RHD conversion, as well as transport to HK cost the same whether it is an old or a new car. However a new car + engine is ~ $12,000 while an old car is around $2,500. I doubt I will spend $9,500 on restoration - $9,500 is more than enough to build a new car completely from spare parts! I will send you a private message so we can discuss in more detail. Maurice Последний раз редактировалось Maurice; 05.03.2006 в 18:18. |
