19.02.2013, 18:57 | #1 |
Engine modification
Hello. I have an Uaz469, year 1982, 2.45 l . Is there any way to make it more poverfull? I tried to increase the compression ratio to 8.5:1, I instaled an electronic ignition, and a K126G carburator. Is not a big thig. The results are poor. Is here any way to put in this engine some biger cilinder and pistons to increase the cubic capaciti? Should I do something at the cilinder head ( valves )? Is any engine that can be fitted easily on this car? Thank you
20.02.2013, 12:44 | #2 |
Тебе сюда. http://forum.uazbuka.ru/forumdisplay.php?f=15 Правда все по русски.
20.02.2013, 15:07 | #3 |
You are right. But I can't understand much from there. Too many topics and I can't find a disscusion of modifying this engine or replace it. Maybe if you can show a link to something more specific of what I need. Thank you
21.02.2013, 09:48 | #4 |
Давайте начнем отсюда. http://forum.uazbuka.ru/showthread.php?t=1500
Но я бы , вместо попыток добавить прыти этому несчастному , посмотрел бы пристальнее здесь.http://forum.uazbuka.ru/forumdisplay.php?f=38 И там уже , в зависимости от доступности имплантируемого органа , выбирать какое пламенное сердце ему вживить. Последний раз редактировалось Олег34; 21.02.2013 в 09:52. |
24.02.2013, 16:02 | #5 |
Only way - swap other engine. This engine - dinosaurus.
03.06.2013, 16:54 | #6 |
Install K-135 carburator, it's from GAZ-53, but you've to change jets. Some where here was written about installing 100 mm cilinder and pistons from ZMZ-410 or UMZ-421 and the the cilinder head from UMZ-421. So you'll have 3 liters engine.
